What value are these LCD TV LG M2762D-PC capacitors?
Hello all,
I have this LG TV M2762D-PC, this is a combination of TV and computerscreen. Bought it in april 2010. Use it as a TV and worked great till yesterday. 10 seconds after powering up, the display went black, sound was still ok. The remote control still worked for on/off and volume, but could not change channel anymore.
I managed to open the TV and take out power supply.
PCB 3PAGC20002A-R
No bad caps but one burned BLUE ceramic 'C'. There is nothing marked on this 'C', so I don't know what value this is. It looks the same as the other blue 'C's on the pcb.
1/ anyone can tell me what value this ceramic 'C' is?
2/ I guess this is not a multilayer pcb. As you can see the damage on the pcb, is it still ok to repair this pcb by replacing the 'C' or should I look for a replacement pcb?
I already have done some repair on monitors (bad caps) and mobile phones (replace digitizer and lcd), so I can handle a solder gun. :-)
Thanks for reading and even more thanks for any answer that can help.
Pierre.
UPDATE 03/03/2015:
Today I managed to take a macro photo and see some identification on the other ceramic capacitors.
It says:
.LY
SL6KV
5D
I think this is high voltage capacitor (6KV)
Anyone can help? Where to buy these?
UPDATE 21/08/2016
Almost one and a half year later, after replacing the burned capacitor and replacing the other one that changed color as well, the unit is still working, but there was this burning smell...
The pcb now looks like this!!
Is it the chemical residue from the old burned capacitor that caused these damage?
Time to look for another pcb I guess...
Any suggestion welcome.
Is dit een goede vraag?
Thanks a lot Oldturkey03,
Your answer was very accurate and helpfull.
Googling 3PAGC20002A-R or PLLM-M901D learned me this is a common problem with this pcb. I will search in a local shop (electronic components) first.
Greetz from Belgium.
door Pierre
Yes, very common problem with the circuitry in that model. Glad I could help.
door oldturkey03
Last update:
Yesterday, I received the ceramic capacitors 5pF 6KV and installed them. This TV works great again. Thanks for helping me out.
door Pierre
Where did you purchase the capacitors?
door Darlene
Hello Darlene,
I have found these capacitors in a local shop (electronic components).
There is also the answer from oldturkey03: Mouser.com
Hope this helps.
door Pierre
4 commentaren meer tonen
