My symptom, front windshield washer works, rear one does not.
Ford uses a common pump for both front and rear washers. There are 2 hoses coming out of the pump, one to the front washers, the other to the back washers.
Front washer - 12 Volt powers the pump to pump water to front washer.
Rear washer - reverse the voltage to the pump, reversing pump direction to pump water to the rear washer nozzle.
I have removed the pump from inside the fender well. When I connect 12 Volts to it, pumps water out one discharge port. When I reverse the voltage (and therefore reverse pump direction) it pumps water out the other discharge port. When I put the pump back in, I can operate both washers supplying external 12 Volts and reversing the connection.
My problem is the pump operates to the front windshield, however, does not operate the rear washer. It does not operate, there is no voltage present and no clogs in the water line. I can blow air through the line and it bubbles in the washer tank.
I have changed the pump, the turn signal switch that activates the front/rear pump and the rear wiper. Fuses are good for both front and rear wipers.
Obviously a wiring problem since I have changed every component in the system.
Where to start looking?
7 opmerkingen
Brian, did you find out what was causing this? I have the exact same problem. David
door David
Brian, did you get a resolution to your problem? I'm having the same issue. Doesn't seem right that it could be the pump, since it appears there is a separate pump for front and rear.
door davetodd5
Hey Brian,
I'm glad to hear it was a simple pump to replace.
PT
door Paul
Which pump did they replace since both front and back were not working? Or did they have to replace both??? Just curious, mine Escape is doing the same thing.
door jbirk
having the same problem went to local AAA car service, they first asked to sign for $99 diagnostic labor. Then after they checked waved the charge since the problem with no spraying in front and back was solved in a min by untangeling the line leading from the reservoir to the nozzles. Solved.
Before I went to this service I have excuded the bad fuse, since the windshield wipers (front & back were working), also that the pump is working by opening the window and the engine cover and listening whether the pum is working, i.e., producing a noise. So talking to the mehsnic I indicated that he needs to check for cloging, or else with the line, and he focused and found the cause very quick.
door vik1919
2 commentaren meer tonen
