Ga door naar hoofdinhoud
Modern rebirth of John Cooper's classic automobile, made by BMW.
13 Vragen Bekijk alle
How can I replace a glove box door?
Glove box handle broke and I fixed it but have no idea how it mounts. Is there an illustration somewhere that shows how it mounts?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
here (click) is a link to mini2.com.
there is a pdf and some instructions
good luck
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Great info source. + Ralph
door
I recently replaced mine. Couple of screws across the top, two on either side, and one torx in the back. There's a vent tube that you place in after the replacement, and the valve connection for this you have to transfer from the old box (this was a very tight for both the old and new box so be careful, it's twist-lock, a lot of wiggling and cursing). You also have to transfer the light assembly, which removes downward into the box.
Score 2
Voeg je antwoord toe
Richard Capuozzo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 18,841
