Ga door naar hoofdinhoud
Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
86 Vragen Bekijk alle
Idle high, Overheating occurs quickly
1994 honda accord coupe had water pump replaced. Idling is high. Overheating occurs quickly. Cant figure out where the water is coming out of. Should radiator be replaced?
Is dit een goede vraag?
Score 1
2 opmerkingen
Is the water leaking? Checked the thermostat? what else did you check? do your fans come on?
door
Water is leaking. Fans come on. Thermostat was replaced. But there is water leaking from a area underneath the radiator.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Tina, check your radiator hoses to make sure they are properly clamped and that the hoses are okay. If so, it is possible that your radiator is leaking. Any shop should be able to do a pressure test to see exactly where it leaks. Yes, there is a distinct possibility that you may have to replace the radiator.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Tina zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 1,159
