Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2521 Vragen Bekijk alle
Replace power cable but power button still not working!
I replaced the power and volume button cables with a brand new cable ordered off of Amazon. I can plug in the phone and it will turn on but when I go to push the power button, nothing happens except for the button clicking noises.
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
You could as well try a new cable and do like Duane suggested: connect it to the board before replacing it, and try to see if it works properly. Then replace it. You probably have a damaged or defective power/mute/volume cable because Volume Up/Down functions on the board have a different circuit from the Power On/Off circuit - UNLESS you have a damaged connector where those 2 functions meet; that would be the connector that connects the cable to the logic board;
Or that connector is dirty (clean it with a cotton swab dipped in 90%+ isopropyl alcohol);
Or the cable is not seated properly: disconnect then reseat the cable.
Was dit antwoord nuttig?
Score 1
It is possible that the replacement cable is faulty or the connector on the logic board is damaged. I would try another Power cable and go from there.
These are VERY fragile. I would suggest when you buy another, simply plug it in first and check it works before doing anything else, that way you know if it is working before taking everything apart (I'm assuming you swapped it all over)
Let us know how it goes :)
1 Opmerking:
When I plug it in everything works except for the power button and volume buttons.
door
Is your home button working okay? If not--look for pry damage along the edge of the board under the interconnect cables next to the battery. If home button is working okay, then this is probably just a bad flex, or damage during installation, or damage to the power flex connector itself---like these smart folks above me have suggested :)
jessa
1 Opmerking:
Damage in that area also affects volume up/down?
door
Voeg je antwoord toe
Tammy Alam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 103
