How to clean the new Mac Pro?
How can I remove the dust from the insides of the computer without doing any harm?
Is dit een goede vraag?
The 2013 revamp of the desktop Mac series known as the Mac Pro.
Can'ed air and a soft paint brush for anything stubborn.
You do want to be careful here with static electricity!
Personally I adopt this method: I remove the protective cylinder, and insert a small plastic insert into the upper fan which prevents the fan from turning and getting damaged. (It must not turn by the compressed air; the circuit would fail). Then I blow the whole Mac with the compressor starting from the sides and going down, still blowing from the bottom upwards. Then I also pass internally to the cylinder, especially in the upper part where there is the upper curvature. In case the dust does not go away, I use a very soft, clean cloth. The air must obviously be as dry as possible and free from dirt. If you need to pass a soft brush in the most internal and not reachable points.
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 35
Altijd: 1,893
