Ga door naar hoofdinhoud
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
379 Vragen Bekijk alle
Why won't the battery charge
My 3ds Xl will not charge. The charging light comes on but the battery does not charge. I have checked the fuses and they are good.
Is dit een goede vraag?
Score 1
2 opmerkingen
I have got the same problem,but the charging does not turn on.
door
i have the same problem, i have a normal 3ds and even the charging stand won't work
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
First try a new adapter . My son had 2 Adapters that went bad and this same issue happened. Next i would replace the battery. If this doesn't solve the issue then your looking at a problem with the charging circuit.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Yea. This is what I figured. I can put the battery in another 3DS (using the same adapter) and charge it and then it works until the battery dies.
Trying to find the fault in the charging circuit. Thanks
door
For my problem are the same also,, it only can play while in AC but not in battery .
Voeg je antwoord toe
Mental zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 4,146
