Ga door naar hoofdinhoud
Part Number: DD11210 The TotalPond pump, which was designed for water gardening enthusiasts, circulates 210 gallons of water per hour, maintaining the ecological balance of small ponds. It is used in water garden less than 3 feet by 6 feet ponds and waterfalls to provide streams of water up to 7.8 feet high.
2 Vragen Bekijk alle
Vraag afgerond
Why is my pump making a strange noise?
I have a pond pump that started making a high pitch noise. Any suggestions on how to make it stop?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
The noise is most likely an indication that the motor has failed. It will need to be replaced, along with the impeller assembly.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 437
