Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Digital music, video and photo player with FM radio manufactured by Sony in 2012.
7 Vragen Bekijk alle
My sony walkman seems to shutdown while charging
Whenever I plug in the Walkman to charge it, it shuts down after a few seconds. I don't know how to fix this situation. Please help!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
This could be the result of a number of issues
The USB cable is not connected to a USB connector on your computer properly.
Disconnect the USB cable, and then reconnect it.
Use the supplied USB cable.
You cannot charge the battery when the icon appears. Charge the battery in an
ambient temperature of 5 °C (41 °F) to 35 °C (95 °F).
The computer is not on or may in sleep or hibernation mode. Counteract these settings. Connecting your Walkman via a USB hub may not work. Connect the Walkman to your computer using the USB cable (supplied). You have not used your Walkman for more than a year. Depending on the conditions under which your Walkman is used, the battery may have been deteriorated. Consult your nearest Sony dealer.
Was dit antwoord nuttig?
Voeg je antwoord toe
Matthew Hintz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 365
