Ga door naar hoofdinhoud
Nokero Window Solar Flashlight model number N400. White plastic, solar panel, suction cup and 3 LED Lights. Also known as Antero Window Solar Flashlight.
3 Vragen Bekijk alle
Why are my flashlight bulbs dim?
When I turn the flashlight on, The LED light bulbs in my solar flashlight are weak or do not give off as much light as they used to.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If all of the LEDs are dim, that is due to a low voltage battery, or an old worn battery. The best course of action for that is to place the flashlight in a window and let it charge, then try testing again. If the LEDs are still dim, I recommend replacing the battery with a new rechargeable battery.
If not all of the LEDs are dim, or the above solutions do not work for your device, check the Nokero N400 Troubleshooting page.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Kyle Burwell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 13
Altijd: 1,542
