Ga door naar hoofdinhoud
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
372 Vragen Bekijk alle
Backlight works, but no image
Hi.
While I repair this MBA 2009, checking devices, suddenly funny beep sound beeping, then display gone black.
That moment, I thought just gone black screen, so I rebooted but display not shows screen. Backlight works fine and boot up OK. Even fn+f1 or fn+f2 could dimming the backlight. Only not image.
Also I tried external display, but that's not work either. No signal.
In this case, what should I check and what could be wrong? By the way, there's no sign of either visual-physical damage or funny smell.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Laptop batterijen
An easy fix for a big power boost.
Nu winkelen
Laptop batterijen
Nu winkelen
2 Antwoorden
Gekozen oplossing
MCP is dead, toss this in the trash. This is not an easy chip to replace even for those skilled with BGA rework, and you will NEVER EVER EVER find this new, they are all gone.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Ouch! Thats not good ;-{
I suspect you lost your GPU. Have you tried an external monitor to double check things. If it too won't display an image its time for a new logic board.
Score 1
Voeg je antwoord toe
Anonymous zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 4
Altijd: 467
