Why won't my laptop turn on?
Hi, i have a iBook Apple laptop. I try to turn it on but It will Not turn on or make any sound and i dont know why? So i was wondering if someone can help me with it?
Is dit een goede vraag?
PowerBook G3 Series (M4753)
1. If the computer is on, turn it off.
2. Simultaneously press Shift-Fn (function)-Ctrl (control)-Power.
3. Wait 5 seconds.
4. Press the Power button to restart the PowerBook computer.
PowerBook G3 (M3553):
The PowerBook G3 (M3553) has two different ways to reset the Power Manager. The first is to use the reset button to the left of the Serial port.
Resetting the Power Manager
2. Restart the computer by holding down the reset button to the left of the Serial port for 10 to 20 seconds.
3. If the computer does not restart, repeat step 2 three or four times.
Resetting the Power Manager and PRAM
Resetting the parameter RAM (PRAM) when the computer is shut down also resets the Power Manager. The following process resets both the Power Manager and the parameter RAM.
2. Make sure the Caps Lock key is not down.
3. Restart the computer. Immediately after hearing the startup sound, simultaneously press and hold Command-Option-P-R. (If you do not hold down the key combination within 5 to 10 seconds after the computer restarts, you must repeat steps 1-3.)
4. Hold down the keys until you hear the startup sound again. Then release the keys.
5. If the computer shuts itself off, press the reset button on the back of the computer to turn it back on.
6. When the computer has finished starting up, restore any custom settings for the desktop pattern, memory, network, AppleTalk, trackpad, power conservation, and so forth.
Was dit antwoord nuttig?
Yes when its plugged in,the light does light up on the adapter but the laptop still won't turn on.Do you know what it could be??
Does these same instructions apply to the kind of laptop i have because i have a Apple iBook (12"- i think) (White)? it complies with the Canadian ICES-003 Class B spec. if you need a lil more info.,let me know.
Look on the back to se if you can find a "Axxx" number. The steps I gave you wouldn't HURT on any iBook.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 4,945
2 opmerkingen
Does the AC power adapter light up when you plug it in?
door mayer
Does it "just say no?"
door mayer
