Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
Why does my MacBook Pro put itself to sleep while I'm working?
Starting out of the blue a couple of days ago, my relatively new Macbook Pro (running Yosemite) started randomly putting itself to "sleep" while I am working. What I mean by "sleep" is that the screen goes black, it pauses iTunes, and it signs off of any Skype calls that might be in progress. I am mystified about how to fix this.
Further clues to aid would-be troubleshooters:
  • This is unrelated to "Energy Saver" settings. I have it set to put the display to sleep after 5 minutes of inactivity, and the computer to sleep after 15 minutes. Yet this issue occurs as I am working --literally while I am typing. It is not falling asleep due to inactivity; it's more like narcolepsy.
  • Interestingly, it doesn't behave as it does during a normal sleep. In a normal sleep, you can wake it back up by tapping the trackpad, pressing a key, or pushing the Power button. When it does its narcoleptic thing, it only wakes back up when I tilt the whole machine to the right.
  • Wondering if it might be a motherboard issue (just a blind guess), I drove to my nearest "Genius Bar" today. The guy took it apart, said the motherboard looked great, and told me that it could probably be fixed by downloading the most recent Yosemite update. Unfortunately that did not solve it either.
Any ideas?
Is dit een goede vraag?
Score 11
16 opmerkingen
Can you give us the last four digits of your serial number so we can correctly identify your system.
door
Apple MacBook Pro "Core i5" 2.5 13" Mid-2012 Specs
Identifiers: Mid-2012 13" - MD101LL/A - MacBookPro9,2 - A1278 - 2554*
door
Did anyone ever find a solution to this problem? I am struggling with it now and I need to be able to do a Skype interview soon, but my laptop sleeps too sporadically.
door
I have the same problem with my MacBook Pro. However, the situation occurs very inconsistently. Sometimes I can work for multiple consecutive hours with no issue. Other times, I'm plagued continuously through a work session. Very frustrating.
door
@Lee Reaviel - Its best to create your own question with your systems details instead of tagging onto an old one as sometimes we just don't see it. Just look above your comment here, sadly, Nil was looking for help and his comment was never seen.
door
11 commentaren meer tonen
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
I might know. If you keep a magnet close to the top of the speaker grill it will put the Mac to sleep (lid closed sensor is a Hall sensor and magnet)
Was dit antwoord nuttig?
Score 33
30 opmerkingen:
This actually solved my problem. I was working with my macbook over my magnetic flip-over leather cover and I actually found the spot which would put the mac asleep and wake it up!
door
Thank you! This was driving me nuts; I had my kindle (with a magnetic latch) resting on the edge of the laptop while I waited for something to compile - and the suspends kept disconnecting my VPN.
door
oh my gosh i just got a new wallet with a magnetic money clip and my laptop was on my lap with my wallet in my pocket. you are amazing for pointing this out. i feel stupid... hahah
door
Holy crap! Thank you so much! I was freaking out because I don't have AppleCare anymore (due to the fact that I got my Macbook in 2012) . I was watching Netflix and it started doing this and I couldn't figure out why. Turns out it was because I had my bluetooth speaker resting to the left of my trackpad below the keyboard.
door
I just bought the Incase Icon cover and it has a magnet on one end that hold it shut. I have always rested my mac book on top of whatever case I usually stored it in. Long story short, I was about to take my new laptop back when I saw this post so I held the magnet to the laptop a few times and that ended up being the issue. Thanks :)
door
25 commentaren meer tonen
Disconnect the battery and the sleep wake sensor on step 14 MacBook Pro 13" Unibody Mid 2012 Left Speaker Replacement
put a piece of electric tape on the sleep wake sensor cable ,dont connect it and reconnect the battery and close the back lid and test it and see if you get the same issue. If you dont thats your problem needs to be replaced. If you still do let me know.
Score 2
Dit antwoord was oorspronkelijk aan een andere vraag gericht.
See
Constantly going into sleep mode, OK in Clamshell MacBook Pro Retina
Like that post,
I think this happens to me because I have a smartwatch and move it around that left side of the computer and the magnet sensor picks it up and thinks the lid is closed.
I have done nothing to fix it and am just trying to not move my arm over to that side of the computer.
Voeg je antwoord toe
Laura zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 80
Altijd: 96,613
