number 7 internal connector
What is the function of the number 7 connector? I may have damaged the ribbon portion and need to locate replacement parts.
Is dit een goede vraag?
antenna flex connection.has small gold prong on right side to connect to bezel
Was dit antwoord nuttig?
anyone else?
I don't know for sure, but I always thought that ribbon was related to the internal compass...
Try taking a small thin copper wire with a small amount of solder on each end. Place it directly in the center of the logic board 7 female connection. Heat up the wire so the solder makes a solid connection on the logic board. Then apply generous amount of solder on the male 7 connection coming off the dock. Connect the two wires and you should get full reception on your antenna.
Good Luck.
“I am so clever that sometimes I don't understand a single word of what I am saying.” Oscar Wilde.
The 7 connection goes to the wireless antenna sticker that resides on the back of the 3GS dock assembly. You can order the antenna on the net for cheap and iFixit has plenty of content on how to replace it.
Parker, thanks for your help! I'll try to do it topmorrow morning. I'll reportto you on the result...
sounds like a good fix-should work.
Good Luck.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 22,037
