Ga door naar hoofdinhoud
Repair guides and troubleshooting for the HP Chromebook, an 14 inch HP-brand laptop computer that runs on the Chrome operating system (OS).
Unable to charge chromebook
My son's HP chromebook's charging ability got worse and over a few months last year, to the point that it does not charge at all. The cables have been demonstrated to be working. Has anyone attempted to fix the issue - I'm guessing that the charging port "desoldered" from the board but I haven't had the chance to take it apart yet.
Thanks!
Keith.
Is dit een goede vraag?
Score 5
2 opmerkingen
I have the same issue, and getting ready to toss it too.
Not good, because the laptop isn't even a year old.
Warranty was 90 days
door
I work at a school doing chrombook repairs. We honestly haven’t found a reliable source for 14” batteries that are reliable. Most of them fail and have awful battery life. The 11” are the best we’ve found.
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
I also have this issue my Chrome book will not charge at all I am going to attempt to replace the dc jack if you have the model number q020nr I believe the dc jack is replaceable with out soldering.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
I have had this problem as well on multiple occasions, even after sending the Chromebook in for a replacement. It appears to be a serious defect for the device.
I've tried jiggling and wrapping the cord around the computer, with mixed results. At this point, I may simply throw the computer in the garbage and get a Samsung model.
Score 1
I had the same thing happen to me. I opened up the Chromebook, and did some poking around. Everything looked fine. I put the device back together again, and it started charging again. I probably caused “Embedded Controller” to reset as in this article https://thedroidguy.com/2018/05/troubles...
Score 1
I have had this problem most of the time the solution is to do a hard reset which is done by holding the power and refresh keys for 10 seconds
Voeg je antwoord toe
kmattox zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 4,464
