Ga door naar hoofdinhoud
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Vragen Bekijk alle
iPod has sad face whenever I turn it on.
I recently changed the battery , headphone/hold button and back piece to my 5th gen iPod , and ive restored it a couple of times and now its giving me the sad faced iPod and tells me to go to www.apple.com/support/iPod . dont know what to do ?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Sad iPod icon with exclamation point
This icon means that the disk scan was not able to recover the hard disk data. Here's what Apple says to do to fix it:
http://support.apple.com/kb/TS1373
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
It's really annoying going around trying to do research on these devices and finding your canned responses everywhere. It was 10 years ago, but god, your account was just used for spam.
door
@pixelperfect If you don't like them, don't read them.
door
Hi,
as you already changed the battery, headphone and back cover, it seems like you know what to do to fix it. First make sure that the hard drive cable is seated properly on both ends!
Most common when the sad face icon appears is, that the hard drive is corrupted/damaged.
But, you should try this first. Follow the link and set the iPod to disk mode, then hook it up to a computer and restore it via iTunes.
http://www.command-tab.com/2006/03/30/hi...
Set the iPod to disk mode sometimes needs a couple of tries, once it took me half an hour.
If it can´t be restored it means, the hard drive is damaged OR cannot be read. That means, the hard drive itself is damaged OR the hard drive cable has been flexed one time to often during repair.
As the flex cable is very cheap in terms of a new hard drive, i would give it a try and buy a new flex cable, before i would buy a new hard drive.
Score 2
i myself do not know i pods much but i do know that it indicates that an HDD error occurred.
you might want to try to listen to the HDD before you do anything
If it sounds very normal,
Try reseating the HDD
or as other people mentioned replace the cable
If it sounds abnormal
if it sounds like it is straining to free itself to spin
try holding the iPod upside down and see if it works if you power it on
if this fails do this at your own riskhold it to your waist and drop it
i don't remember why but it solved the problem for somebody
if you hear humming
your spindle motor is probably stuck , there isn't really anything you can do about that (really painful thing to happen )
if it has been exposed to where it could have fell or it has been dropped
though very rare your read/write arms could have crashed into the platter. not much recovery from that
if your hear trashing/scraping noises
i really don't remember what this means but it is probably dead
if it is squealing/screaming/squeaking, clicking
HDD heads are failing and there isn't much to do
but to attempt data recovery
###############################################################################if it isn't showing any sings of death , then yes try a restore
it however may not bee the HDD it could be something faulty between the hdd and whatever reads from it (better be the CPU if i am not mistaken) if possible if you suspect a failure like this open it up and inspect closely for any signs of scorches,corrosion,cold solder joints
this is all i would know
please report back
2 opmerkingen:
sorry for my answer being so long
door
oh yeah if you do drop it on CARPET
that advice solved this persons problem
https://discussions.apple.com/thread/177...
door
Hi, i just buy an ipod video G5 30gb 15 days ago, cheap, about 10$usd because the problem with this was the legend : battery very low, please wait.... so when i open, i saw i little issue in the battery cable connector, 2 pins united with a pellet (i don know the name in english, in spanish is "sarro", google translate said sarro=tartar....) so i buy a new battery but when i connected, my ipod 30gb wake up with a SAD FACE....
How is possible if was working, (interface) good, the only and principal problem was battery... i was trying everything, buton select+menu and right away select+play to put in disk mode the ipod, with this the ipod only get battery charging, and the PC or Mac not detect the ipod like external disk or something... so this isn´t a solution......
I read two things interesting, first theory to fix SAD FACE, is drop the ipod against the floor, from 2 meters or something high... to get the internal pieces from Hard disk unlock.... it sounds like it makes some sense but danger for our ipods....
Second theory, sometimes, when you open frist time an ipod, (first time for the ipod, not for u) some connections get losse in some points, and is a coincidense when you replace a display for example and get a sad face, or like my case, for replace a battery a get the SAD FACE in my ipod video, this sound with sense too...
So i decided to combine this two possible solutions, i open my ipod, disconnect battery, hard drive and the other flex cable to connect in middle of logic board, i wait 5 minutes, and hit a little the hard drive against my other hand, past this, i begin to assemble everything, first the hard drive, second the flex cable who contain the 3.5 jack, last the battery...... and guess what? this method WORKSSS¡¡¡ now this ipod video is working, i restore and i put music and videos to test, and yes, everything is working fine
Voeg je antwoord toe
victor napoles zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 163
Altijd: 29,181
