Ga door naar hoofdinhoud
The iMac G5, powered by the PowerPC G5 processor, was originally released in August 2004.
453 Vragen Bekijk alle
Vraag afgerond
Computer recognizes drive but I can't erase or initialize
Hello, I recently purchased a 3 TB Toshiba internal hard drive that I want to use as a second drive in my Duel Mac 2Ghz PowerPC G5. The computer recognizes the drive but I cannot erase or initialize the drive. I'm running Mac OS 10.4.11. Any help would be great, thanks!
Tym
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
More than likely you are having a SATA problem. The HD you recently purchased may promise to be backward compatible or automagically self limiting (and should be) but I belive it's not working.
Your ID fits 5 different versions of the G5 box, but all use SATA I HD's.
You may be able to manually set the SATA speed of the drive. If not you may want to try a different SATA cable or need to find a different drive.
If this answer is acceptable please remember to return and mark it accepted.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
I think the problem is my computer uses ATA, not SATA, for the internal hard drives.
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 108
