Ga door naar hoofdinhoud
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
735 Vragen Bekijk alle
Wifi No Hardware Installed
I am not getting wifi. I had a no hardware installed message, before i reinstalled OS X. Now i don't even have a wifi option. Bluetooth and I sight works fine.
What I've tried so far. Ive replaced the wifi card. Same result
Next I ordere a used cable and tried that without removing the display and attaching one end of the cable to the i sight camera. This gave me no wifi or bluetooth (or i sight because i didn't hook that end up ) I thought this cable may be defective so i ordered another one. Same result. Do i potentially have three bad cables, or do the two "new" ones have to bee connected to i sight in order for wifi and bluetooth to work. Thank you in advance.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Check the card connector. Someone here with similar problems found out that they had bent a pin on the connector (they too tried multiple cards). Fortunately they were able to straighten the pin without breaking it off.
If this answer is acceptable please remember to return and mark it accepted.
Was dit antwoord nuttig?
Score 2
Commentaar:
I inspected both sides of the connector they look good.
door
Did you use a mirror and a light and look inside the slot?
door
Voeg je antwoord toe
Kent zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 1,049
