Ga door naar hoofdinhoud
First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
71 Vragen Bekijk alle
What is that hole under the glass on the top?
What is that hole under the glass on the top of the scree? A sensor? An hidden camera for iOS 4 Face Time?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
some devices are using light sensors to adjust the screen brightness.
i don't have an ipad - when i look at my nokia phone - i see also a "hole" - and that is for sure a light sensor.
Was dit antwoord nuttig?
Score 2
Markus is correct, that hole is an ALS or, ambient light sensor. It is really only used for one thing, tha auto-backlight feature that you can enable or disable under the settings menu. Unfortionatly, it isn't a camera, and every iDevice has at least one (iPhone has a few for detecting when someone puts their face up to it) and that's about all it does.
Score 1
I had the same question as well, until I tried to place my finger over the said hole when the ALS option is activated, but it didn't change the brightness on my screen at all. I'm not sure what it can be then otherwise.
It is the front camara and nothing else!
1 Opmerking:
There isn’t a camera on the iPad original, I should know, I have one.
door
ALS(ambient light sensor
Voeg je antwoord toe
Rodrigo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 14,382
