Does any one know of a Windows version of Carbon Copy Cloner?
Hi, Just completed my latest build and would like to find a Windows version of Carbon Copy Cloner to clone the hard drive. Ralph
Is dit een goede vraag?
sorry ralph, CCC is a mac only program.
windows is not able to read the mac partition/formatting without extra tools.
the only useful program to access mac files on a windows system is transmac (i used it to modify my setup dvd in order to setup 2 of my hackintoshes (asus eee 1005ha and vaio p11z)
maybe clonezilla could do the clone job
Was dit antwoord nuttig?
Looks interesting Markus--just might work. I appreciate that CCC is Mac only -thats why I'm looking for something similar for Windows. Thanks for the lead. Ralph +
argh - wait, i think i misinterpreted something - you want to clone a windows partition - right (i think i should go to bed - i'm almost 20hrs up and had no coffee the last 5hrs ;-) )- cloning windows will work with clonezilla - but it will only work for computers with same/similar hardware - but i think you knew that already
But that only applies because of drivers, correct? If you deactivate (or just leave it alone) the old drivers, and load the new ones shouldn't it work? I've pulled HDDs from computers and put them into others and it was a tad bit slower but I just needed to install drivers and it was good to go!
Hi markus, Thanks for the info. I may decide to hack this unit--if I do can I pick your brain off forum on the subject? If yes I will find some way to get you my email address. Ralph
hi gabe, yes - it's a driver issue - but there are some windows live usb/dvd systems - sometimes pretty useful. hi ralph - no problem - my adress is markus.weiher@gmail.com
Shadow Copy Cloner, available from www.goldentroutsoftware.com, will clone your Windows system partition to a partition on a second disk on a PC. In the event of a disaster, you can install the clone in your computer and boot it. It appears to be modeled after Carbon Copy Cloner, so it might be what you are looking for.
It would appear this program may do what I want. Thanks
This is a valid answer
+ agree with rj valid answer
why are we voting on this then? seems it answered your question...
ABC - you voted to remove this as not an answer
Norton ghost and internet security suite have this ability too. If you have comcast you should get norton iss for free. Goto comcast.net login, goto security.
I have used Casper to clone a disk drive and successfully replaced the original HDD with the cloned drive. Did this successfully to replace a HDD with a SSD.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 35,773
1 Opmerking
This Post was migrated from http://meta.ifixit.com/View/428/Does+any....
door Sterling Hirsh
