Ga door naar hoofdinhoud
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
368 Vragen Bekijk alle
What counts as unrepairable? (PS4 Controllers)
I am buying a joblot of faulty ps4 controllers and am wondering what types of problems are unrepairable? I know analog drift, cracked shells, worn nubs and usb ports can be replaced or repaired but what would indicate a problem with the motherboard, which I heard can't be replaced?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
MARs, broken (cracked or otherwise physically damaged) circuit boards are pretty much done for. component repair will depend on your skills and tools. It can all be repaired, for as long as you know how. There is no specific answer since it will be entirely up to you of what is unrepairable.
Was dit antwoord nuttig?
Score 3
9 opmerkingen:
So you're saying most problems bar physically damaged circuit boards can be fixed? (Does this include water damage?)
When buying ps4 controllers, what sort of problems would most likely indicate a broken board? What sort of descriptions should I be wary of when buying controllers?
door
unresponsive would be the one I'd be leery off. That could be caused by multiple things and usually turns into a money pit. It will also depend on who is selling and why. Water damage can be fixed, but is very hard to diagnose. To purchase something like this is always a gamble....
door
Thanks for replying, just a couple more questions if it's not too much trouble.
Things like the controller being unable to sync, or not charging would also indicate a motherboard problem?
Lastly, I'm buying these controllers off ebay and costs from p&p tends to add up, where would be the best place to buy broken ps4 controllers outside the internet? (I'm in the UK.)
Thanks, again.
door
unable to sync can be a circuit board issues and not charging can be as simple as a battery connector or even a bad battery to as bad as the power management circuitry. As where to buy, that is a real big depend. I would check actual electronic auctions, universities, fleamarkets, and newspapers.
door
Thanks again.
door
4 commentaren meer tonen
Use the defective ones as "remote PS4 power on switches". Solder a pair of wires to the PS4 wake/menu button and then connect to an Arduino.
It's pretty awful you can't turn on PS4s (or wake them) using third party remotes. I'd sacrifice/hack one of my own PS4 controllers, but they're in perfect shape still (and expensive to replace).
2 opmerkingen:
I have question hopefully someone can answer. Ok so I buy used Ps4 controllers and give them a paint job and afew mods, make sure they are in good working condition before selling. But this time recently I was installing a trigger stop on the R2 button trigger stopped working after that I took the controller back a part and found that the clear rubber was ripped and pulled away from the conductive film I tried replacing the clear rubber from the L2 button to see if it would work and it doesn't do you think replacing the conductive film should work?
door
I'm no authority, and remotely I can only guess. If ALL you did was rip a clear insulator then nothing would have broken. If removal of the insulator allowed something to short, even temporarily, then it could be fried (a guess). Also possible there's hidden damage to a conductor or trace, meaning the device is OK but the circuit never completes so you have to find the break. Best advice is bring it to Open House at your local "makerspace" (Google for that), or a TV repair shop (if they still exist) could figure it out.
door
Voeg je antwoord toe
MARs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 27
Altijd: 6,815
