Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3267 Vragen Bekijk alle
How do I unscrew the battery connector screw?
I'm trying to unscrew the battery connector screw with the Phillips screw driver which came with a kit I bought from Amazon. I did a mistake by buying from them. I should had bought it from here. How do I remove the batter connector screw?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
Doorblader onze winkel
1 Antwoord
Gekozen oplossing
To remove the back cover, you first need a Pentalobe #2 screwdriver. Then you need a Phillips #000 screwdriver to remove the screw holding the battery connector in place, and finally a plastic opening tool to disconnect the battery connector from its socket. Here's the guide that explains everything in details, including tools and parts.
If this answers your question, please mark the answer as accepted.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
iPhonesaregreat zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 40
