Ga door naar hoofdinhoud
Why wont my DigiLand Android tablet's screen rotate?
I have the auto rotate turned on and everything, I have no idea why it won't turn when I tilt my tablet.. Ive turned on auto rotate in accessibility so im not sure what else to try.
Is dit een goede vraag?
Score 5
1 Opmerking
I'm having the same issue with mine. I went into settings, into accessibility, then clicked auto rotate, I already had it checked off but I unchecked the box and the screen flipped back from the landscape format. But now it won't flip around on its own any more even though I've checked the auto rotate back on.
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Have you tried doing a factory reset to attempt fixing the rotation issue?
If after doing a factory reset you're still having the rotation issue, it might be a hardware problem in which case you'd have to get it repaired.
If it's still under warranty from the time you purchased it you can send it in for servicing.
Was dit antwoord nuttig?
Score 1
The same thing happened to me, go to settings, accessibility, then check the auto rotate box, mine was on but when I turned it off it fixed it, though note when I turned it back on it won't flip on its own any more.
Score 1
1.From a Home screen, tap the Apps icon .
Located at the bottom (in portrait) or at the right (in landscape).
2.From the Apps tab, select Settings.
3.Tap Accessibility.
4.Tap Auto-rotate screen.
To choose this option, select the box and a blue check mark appears.
On Google Play there is an app called “rotation control" that will allow you to change rotation because my digiland 10 inch stopped rotating over six months ago - it works!!
Voeg je antwoord toe
Keri zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 3,248
