Ga door naar hoofdinhoud
Cen-Tech digitale multimeter met zeven functies. Modelnummer 90899.
8 Vragen Bekijk alle
Why won't the screen show any readout?
I want to use my multimeter to test a battery. The banana plugs are attached and cords are attached to the device, but the screen is not reading anything. My device is turned on and seems to be functioning otherwise.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
The reading screen is either broken or malfunctioning. You may need to replace the screen. See screen replacement guide here. If this does not seem to fix the problem, you may have an issue with the motherboard. Click here to see how to replace the motherboard.
Cen-Tech Seven Function Digital Multimeter Mainboard Afbeelding
Handleiding
Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
Moeilijkheid:
Eenvoudig
5 - 15 minutes
Cen-Tech Seven Function Digital Multimeter Screen Afbeelding
Handleiding
Cen-Tech Seven Function Digital Multimeter Screen Replacement
Moeilijkheid:
Eenvoudig
10 - 15 minutes
Was dit antwoord nuttig?
I'm all for fixing stuff and keeping it working, but Harbor Freight literally gives these meters away. They're not worth fixing. i have a stack of spare ones still in the package waiting to be used.
Voeg je antwoord toe
Anna Kihm zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,668
