Ga door naar hoofdinhoud
Line of laptop computers aimed at the small business market, designed to replace the Dimension line of laptop computers.
Dell Vostro 3360 won't boot after LCD replacement?
I recently replaced the LCD screen on a Dell Vostro 3360. And it will power on but does not load windows. Pressing f12, looks like it's starting diag but that does not load either. Any suggestions? same for f2
thank,
Lucille
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Lucille, does it give you any beeps sound when you try to power on your laptop.also,replacing the LCD display shouldn't affect booting process unless you have correctly reconnect all the video and audio wires when you replaced the display. I would need additional information if I can help you.
Good luck
Best Shawn.
Was dit antwoord nuttig?
Voeg je antwoord toe
Lucille zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 393
