Are the LCD connections the same between the S4 & S4 Mini?
I am just wondering if the LCD connection is the same between the Galaxy S4 Mini and the Galaxy S4?
Is dit een goede vraag?
No,
The first one is 1080 x 1920 pixels and the second one - 540 x 960 pixels.
Regards.
Was dit antwoord nuttig?
A couple of questions, if you don´t mind.
You mention that "The first one is 1080 x 1920 pixels and the second one - 540 x 960 pixels", does that mean that the connectors are different or that it will work with less resolution?
I have an S4 with a broken lcd. I want to enable usb debugging on it, so I can see the screen on my pc while the replacement screen arrives.
I also have an S4 mini and I was wondering what would happen if I plugged the S4 mini lcd in the s4 connector. Can I damage the working S4 mini screen?
I only need to see the settings screen.
Thanks!
No,
the connectors are of similar type, but they are not the same. The s4 mini connector is a bit longer, so it won't fit. It also has more pins.
I don't know if they are electrically compatible. Theoretically, if you somehow connected the right pins, for example by a custom made connector cable .. it might work, or break something.
Regards,
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 944
