Ga door naar hoofdinhoud
This device is part of the second wave of Polaroid's 600 series cameras that were developed between the 1980's and 1990's. It would instantly develop the film in about three minutes and the battery was integrated into the film pack.
15 Vragen Bekijk alle
Why isnt my flash working?
After pressing the shutter switch, the flash is not engaging, Why?
Is dit een goede vraag?
Score 2
1 Opmerking
I have the same issue, my flash is not charging even when i put a brand new film cartridge.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This is most likely one of two things. The first possibility is that you aren't allowing enough time for the flash to charge. It takes at least 5 seconds for this process to take place but even after 5 seconds you must wait for the red light in the viewfinder to turn off before the flash will work again. The camera won't produce an image if the flash is not completely charged.
If the red light on the viewfinder is off and it is still not producing a flash then it is likely that the battery that is inside the film pack is dead. In this case you will need to replace the film pack.
Polaroid Onestep Close Up Troubleshooting
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Tyler OBrien zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 110
Altijd: 12,760
