Ga door naar hoofdinhoud
The Samsung Galaxy Light is an Android device released in October 2013 for T-Mobile with GPS, microSD card slot, and 8 GB memory.
12 Vragen Bekijk alle
My phone will not charge...
My phone will no longer charge, I am not sure if it is battery failure or my charging port.
Is dit een goede vraag?
Score -1
1 Opmerking:
This could be an issue with your charger or phone charging port, start with trying another charger. If this did not work try cleaning out the port on the phone, if it still doesn't work you will need to replace the micro USB port in your phone to do so follow this link (Samsung Galaxy Light) to see step by step how to replace your port.
door
Voeg een opmerking toe
1 Antwoord
This could be an issue with your charger or phone charging port, start with trying another charger. If this did not work try cleaning out the port on the phone, if it still doesn't work you will need to replace the micro USB port in your phone to do so follow this link (Samsung Ga...) to see step by step how to replace your port.
Was dit antwoord nuttig?
1 Opmerking:
There no guide via your link.
door
Voeg je antwoord toe
Paul Goyette zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 204
