Ga door naar hoofdinhoud
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Vragen Bekijk alle
iPod Touch 4th Generation Screen Won't Turn On After Home Flex Replace
After replacing the home button flex cable, I tried to turn the ipod on and nothing happened. I plugged it into the computer and it recognized it, but it has a passcode, so I can't restore it. I don't know if the new home button works or not, but I can't turn it off to put it into DFU or recovery mode. The flex cable for the screen doesn't look damaged. I can't see anything at all, so I don't think it is the back light. Is there any way I can fix this? Do I need a new screen?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Unfortunately, you will need to replace your screen as there is no way to separate the back light from the assembly. Hope this helped!
Was dit antwoord nuttig?
Voeg je antwoord toe
Trevor McClellan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 193
