Ga door naar hoofdinhoud
My Galaxy GT-P5110 won't hold a charge or turn on. Please help!
I tried leaving it plugged in overnight, I even took it to the geek squad at best buy, and the samsung salesman...nothing. I bought the tablet in Germany, I don't know if that matters (I doubt it). Can someone please help me solve this issue. Thanks
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
This is a copy of another answer I gave today:
Perhaps because your battery is dead.
Check your charger plug-in module with another USB device to see if it is still working.
If your plug-in is still working, check your cable for physical damage, such as a deep crimp in the insulation on the wire (which might indicate that a wire was broken inside), or a dinged-up male for the tablet.
There are 7 pins in the charger cable, buried down in the slots on that 30 pin connector, and the other 23 slots are empty. You might need a magifying glass and a bright light to see properly.
Even if you can't see any damage, a replacement cable is less than 5 bucks: buy a new one and see if it fixes your problem.
Remember if your battery is very discharged that it might take a while for the power-off battery logo to appear on the screen.
Was dit antwoord nuttig?
Voeg je antwoord toe
Bryant zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,251
