Ga door naar hoofdinhoud
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 Vragen Bekijk alle
How to remove door panel from 1988 Chevrolet Pickup?
1988 Chevy Cheyenne Pickup. I need help on how to remove the window crank from the door panel?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Wilson, it uses a retainer clip that holds the handle to the window regulator. You can use a Retaining clip remover available at places like autozone, walmart and others. Check this video for some other ideas. Check on here to see how to use the retaining ring remover.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you this was exactly what I needed to know!!
door
Voeg je antwoord toe
[deleted] zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,325
