Ga door naar hoofdinhoud
The Fosera Scandle 200 is a solar powered device that can be used as a lantern and/or a charging station for electronic devices.
Why is my device not holding a charge?
I've had my device for a while now. Lately, it only works when plugged in.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If your device is not holding a charge after a full charging cycle then your battery has likely reached the end of its lifespan. Rechargeable Lithium-ion batteries have a limit for the number of charging cycles they can go through, and as this limit is approached the battery will exhibit much a much lower capacity.
See heading "My device only works when the solar panel is attached" in the troubleshooting page at:
Fosera Scandle 200 Troubleshooting
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Vincent C zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 359
