How do I change the Sim place?
SIM does not work in my phone after falling into the water
Is dit een goede vraag?
abouryad, not sure about "Mobile machine drying clothes" but I would suggest you clean it properly before you have further corrosion damage. Use this guide to see how to clean the phone. The guide was written for an iPhone, but the same principle applies to your phone. Follow this guide to see how to mostly disassemble your phone. While you are cleaning it, take a look at the SIM card reader and see if you have any corrosion damage. It is also possible that you have a shortcircuit because of the water and corrosion damage. All that you should find out when you have it apart and cleaned. Hope this helps, good luck.
Handleiding
Moeilijkheid:
Moeilijk
1 - 2 hours
Handleiding
Moeilijkheid:
Gemiddeld
25 - 30 minutes
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 205
2 opmerkingen
what have you done to stop the corrosion after it fell in the water? What have you done overall to fix it?
door oldturkey03
I used hot air to be dry and then was run Mobile became the SIM show does not show and then was extinguished and placed in the Mobile machine drying clothes and then workman was not working SIM final.
door abouryad
