Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
377 Vragen Bekijk alle
keyboard and mouse pad doesn't work
Hi
I have MacBook Air A1466 . ( 2012 ) keyboard and mouse pad doesn't work. On a keyboard
Just power on switch is working. What's prob on it ? I changed keyboard as well. But it's still
Same prob.
Thanks .
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Have you tried using an external keyboard & mouse, does that work?
You state you changed the keyboard how did you do that? Please explain.
Was dit antwoord nuttig?
Score 1
Commentaar:
The keyboard is riveted into the case on these MacBook Airs, but it can be replaced. It may not be the best way to do it as the keyboard is no longer riveted into the case, but it works.
door
The keyboard connects to the logic board through the trackpad on these machines. So perhaps the problem is with the trackpad. I actually recently ran into this with a customer's machine...it was acting as if the shift key was stuck down, so I replaced the keyboard. That didn't solve the problem so I replaced the trackpad and that turned out to be the issue.
Score 1
Voeg je antwoord toe
Krunal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 296
