Motorola Droid 4 display doesn't rotate after touch screen replacement
Replaced the touch screen on Motorola Droid 4 slider phone and now the display is locked in the horizontal position. I checked and unchecked the Screen Rotation box in Settings but no success.....
Is dit een goede vraag?
2 opmerkingen:
I assumed that the new touch screen/frame assembly from another website would come complete, ready to install the LCD. WRONG! After going into the phone a second time and examining the old assembly vs. new, I found approximately 8 pieces that needed to be transferred to the new frame: 2 medal corner brackets, 4 black "slider stops" (2 on top/2on bottom edges of old frame attached w adhesive,) the black shines bezel plate opposite end of frame from the camera bracket, and MOST INMPORTANTLY... a small rectangular MAGNET along one edge again held in place with adhesive. Reassembled phone and works perfectly!
door
In addition, ("shiney", not shines) there is also a white rubber pad that sits in the corner near the touch digitizer connector component. (I know THIS now....) hope this can help someone.
door
Voeg een opmerking toe
