Ga door naar hoofdinhoud
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
246 Vragen Bekijk alle
My note 3 freezes a lot and doesn't play videos or music
Hello,
My note 3 N9005 all of a sudden started freezing a lot, the camera wasn't working, can't play videos or music
Can't make or receive calls, but data connection is working
When I changed the ROM I could use the camera to take pictures, but still no video recording
Someone told me it is a RAM problem and needed to be replaced
So is this really the case ? And can it be replaced ?
Also the spare RAM part isn't available here for now .. so can I order it online ?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Did you fix your problem i have the same problem with my phone the exact same problem ..what can i do
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Yes it was fixed :D
First you should know I have had already tried installing a different lite rom that made the phone just a little more usable but still broken. I tried restoring a backup that I knew was working , I tried reinstalling all the different versions of the official firmware, I tried giving it to a repair shop that tried to use a Box to flash a firmware but all that didn't work.
Until one time the phone asked for OTA update and I thought I should try it anyway. I didn't expect the problem to be fixed at all but it was.
I guess the problem might have been with knox security software that could only be fixed with an update that had a different version.
By the way before it asked for the updates someone tried flashing a firmware using a Box (but ut didn't work until OTA update was installed)
The firmware version that fixed it was N9005XXUFNF2
You can contact me if you have any questions at moustafaatchy@gmail.com
I hope yours gets fixed too
door
Voeg je antwoord toe
moustafaatchy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 724
