Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3322 Vragen Bekijk alle
Water damaged iPhone now overheating
Hi. Switched off iPhone 5 got flushed through the toilet. Found the iPhone on the 1st floor. After hair drying it it started working. But the battery is depleting fast even when I switch it off. What can I do?
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
Doorblader onze winkel
2 Antwoorden
Het nuttigste antwoord
Maha, the very first thing you want to do is to stop using your phone. Stop right now and do not continue to charge or sync it. The very next step I would do is to disassemble it by following this guide. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. After that I would suggest that you clean it a couple of times in sterile water, not drinking water. Use a soft brush and clean it very, very thouroughly with the sterile water. Depending on the amount of corrosion, you may have to remove all the EMI shields. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. Also, I suggest to replace the lightning connector. The guide for that is here Yes, do replace the battery for sure. Use this guide for that. Keep in mind that water damage is the hardest to troubleshoot and to repair. Hope this helps, good luck.
iPhone afbeelding
Handleiding
Repairing iPhone Liquid Damage
Moeilijkheid:
Moeilijk
1 - 2 hours
iPhone 5 batterij afbeelding
Handleiding
iPhone 5 batterij vervangen
Moeilijkheid:
Gemiddeld
10 - 15 minutes
iPhone 5 Logic Board afbeelding
Handleiding
iPhone 5 Logic Board Replacement
Moeilijkheid:
Gemiddeld
iPhone 5 Lightning Connector and Headphone Jack afbeelding
Handleiding
iPhone 5 Lightning Connector and Headphone Jack Replacement
Moeilijkheid:
Gemiddeld
1 - 2 hours
Was dit antwoord nuttig?
Score 1
Have You tried Lower Brightness and battery saving mode? If You havent, try it. Uf this dosent work You might have to turn off notifications and maybe fully closing an App after You ARE done With it
Voeg je antwoord toe
Maha zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 4
Afgelopen 30 Dagen: 15
Altijd: 5,732
