Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4639 Vragen Bekijk alle
Can the iPhone 6 Plus camera fit in the iPhone 6?
One of the distinguishing factors in choosing between the iPhone 6 and iPhone 6 Plus is the camera. If the 6 Plus's camera fits in the smaller iPhone 6 then potentially you can modify the smaller phone to use the better camera and have a phone which is the best of both worlds. Can this be done?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
Whether iphone 6s plus front camera can be used to iphone 6plus
door
People, I don't care if it were to fit or not. Iphones are unreliable as they are, do not mess up your iphone further and cause some boot loop or fried component.
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
Doorblader onze winkel
7 Antwoorden
Gekozen oplossing
Sorry folks they are not the same size so I doubt it will even fit as the plus unit is the larger and has different mounting. See for your selves:
Yes the connectors are the same but we don't know the how the signaling is managed.
Was dit antwoord nuttig?
Score 3
Commentaar:
Thanks for the info.
door
it works... just have to stick camera with double tape or some adhesive as 6 camera's size is smaller for 6+ camera housing
door
supposing you could get the firmware working, the 19 pins I counted on the 6 cam was the same amount on the 6+, id be concerned about size too though im sure someone will measure that out soon enough.
Would be an interesting hack for sure.
Score 2
Commentaar:
Yes, I think it would be an interesting experiment to see how compatible it is and how much software would need to be altered?
door
Dit antwoord was oorspronkelijk aan andere vraag.
Check out this question thread: Can the iPhone 6 Plus camera fit in the iPhone 6?.
As it looks now they are not compatible as the size of the units are different.
Score 2
I really really doubt if looking at previous phones they made and there interchangablity.
Id say the connectors are completly different
Score 1
Commentaar:
Not to mention I am sure the iPhone 6 firmware will not support the motor hardware inside the 6 plus camera. Even if you did get the camera in there working, it wouldn't work as it is supposed to.
door
Do you have any evidence that the connectors are different or is that a guess? Also, how are you "sure" that the firmware will not support the motor hardware or is that also just a guess?
door
Are they different? Could you look at them? And what about the size? If you took apart the tho phones, it would be possible to check these two things.
door
Any update on this, guys?
I'd love to have the 6 regular with a 6+ cam!
Score 1
Just hope is it a problem of thickness not allowing it fit in 6 vs 6+, otherwise cheap attitude of Apple regarding expensive price ...
Commentaar:
I could see this as an issue, dont know how we could get around it unless its only the bit that sticks out. meaning that the camera lens would simply stick out more on our 6s than before.
door
seeing how the past iphone components were incompatible i highly doubt it. let us know what you discover though!
door
A little off topic but 6 and 6s front cams are interchangeable FYI
Commentaar:
See my post here:
Will the iPhone 6s front camera work on an iPhone 6?
Are you saying you can swap the front cam and rear cams both from a 6s, into a 6???
door
front cams yes, not sure on rear cam but I don't think it would work.
door
Rear camera NO, front camera yes. And i´m talking about 6 and 6s (not 6+).
door
Voeg je antwoord toe
skemez1 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 4
Afgelopen 7 Dagen: 35
Afgelopen 30 Dagen: 153
Altijd: 9,244
