CECH-4301c ps3 superslim 120volts can it be use with 220volts?
i have a cech-4301c ps3 model and i'm not sure if i can use it wiht 220 voltage?
Is dit een goede vraag?
rhy, "In a similar fashion to the PS3 Slim, the power supply is designed for inputs ranging from 100V to 240V AC, making it usable across the globe." you will not need a converter. from here. It is a universal power supply. All you need is a power cord the fits the outlet. the voltage on the outside label will most likely only display the voltage for the country it was sold at. i.e. US 110V. If you do want to make absolutely sure, you will have to open up your PS3 and take a look at the PSU itself. Hope this helps, good luck.
Was dit antwoord nuttig?
what i did was i plug it on 220 volts within a couple of minute once and its seems like there nothing wrong or smell burning on it so can it can be confime that ps3 cech-4301c is 110-220V before i will start a full game on it.. thanks for the replay..
The ps3 is dual voltage but you should confirm that by checking your power supply. First confirm that on the PS3 label is written 120 - 240V.
I am planning to buy the Ps3 CECH-4301C 500GB version!! Bit confused about whether stepdown transformers are needed or not!!?? Can you confirm me here if this is needed or not to use it here in India.?
Thanks,
Siva
You will not need a transformer. the power supply is designed for inputs ranging from 100V to 240V AC, making it usable across the globe."
Thanks for your reply,
I was confused because, I saw the link for that model and in specification Box they mentioned "Power : 120 V AC, 60 Hz" this is what made me feel confused now :(
Here is the link for manual i saw,
https://www.playstation.com/manual/pdf/C...
Please do confirm if any of you have experience without using any transformers!?
What model did you run without transformers!?
Thanks,
Siva
Siva, Can you please confirm if it worked without transformer in india? I am having the same model
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 5,038
