Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Vragen Bekijk alle
home buttom working good but touch ID does not working
Hi.
My friend i have exact same problem.
After replacing screen, home buttom working good but touch ID does not working
I try soft reset home buttom + power buttom it still the same
And i try to reset the phone using iTunes it did not work too :(
Any suggest boss :)
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Normally iphone 5s home button set include a touch IC(only match with your iphone 5s motherboard). I think your iPhone 5s screen replacement include new home button set. that is the reason why touch ID not working. you can use old home button set to new screen.
Was dit antwoord nuttig?
Only the ORIGINAL home button will ever work with Touch ID... unless you get it repaired by Apple. You would need to remove the original button from broken screen and place it in your new one to retain Touch ID.
Try to configure new finger. If you get an error it mean that someone replaced home button before. It's not possible (for now) to repair it because Touch ID chip is paired with CPU.
Score -1
Voeg je antwoord toe
tariq zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 160
