Need broken parts identification.
I'm trying to replace the lightning connector assembly and loudspeaker on my 16gb iphone 5 but I have run into a problem. I ordered and received the parts but they seem to be different or something. First the loudspeaker from my phone had some sort of square flat ground cable stuck to the top of it that had screw terminals at both ends, one screwed to bottom right corner frame and the other screwed to lightning connector screw down. I apparently broke this removing the speaker yet the new one I ordered did not have this ribbon so what is it and where do I get one.
Secondly, the lightning connector and headphone jack assembly I removed form my phone has a ribbon connection on the far left side of the headphone jack and wraps around the back of the jack but is broken there and I don't know where it goes or what it's for. The new part I ordered does not have this on it so again what is it and where do I get one.
Is dit een goede vraag?
1 Opmerking
Thank you Con just ordered them now if someone would be so kind as to update the repair guide to reflect these parts since they are not mentioned that would be great. Thanks again
door jakuzi1
