Ga door naar hoofdinhoud
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
248 Vragen Bekijk alle
Camera on back takes blurry photos? can it be fixed
The camera on the back of my samsung note 3 always takes blurry photos, I have reset my whole phone and everything, it only started doing this a couple of days ago.. please give me some tips or let me know if I can fix it myself or I have to pay someone to fix it??
Is dit een goede vraag?
Score 16
6 opmerkingen
i m facing same problem , all was well and suddenly next day my camera became blurry.it can focus nearby objects upto 15 cm beyond that pics are blurry .there is no scratch or anything.i m no more intrested in fuking samsung.....after this type of pics .........i m just waiting it to explode like note........
door
@atulkumar008 'm experiencing exactly the same.
door
my j7 prime back camera became blurry after i put it in a onsie pocket. this was a couple days before christmas. it is still blurry and i don't know how to fix it. there are no scratches on it. please help
door
I m a j5 user n same bloody problem
door
I find that the inside lens is dirty. I don't have the tool to open and clean it though.
door
1 commentaar meer tonen
Voeg een opmerking toe
13 Antwoorden
Het nuttigste antwoord
Can you see visible marks on the glass that covers the camera? On my galaxy note the glass become marked, it happened quickly and it was almost like someone had dropped some super glue on the glass but I suspect it was that the glass was slightly raised out of the body and was being scuffed when you put the phone on say a table or desk. I was really careful with the phone as it was brand new and so can't think of any other reason. I could have sent it to be repaired but it would have been gone for about a month and I needed the phone.
What I eventually did to fix it was took some car scratch removing cream (cream that removes small scratches from car bodies) and rubbed that on the glass, it took a little while 20min of buffing but the glass slowly cleared and now photos are not blurred at all.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
After repairing the broken SIM card base (GALAXY Note GT-N7000) at a local inexperienced shop, the back camera became blurred. After hitting the mobile by my palm, the camera recovered for a week or so. Later, it became blurred again. Despite thst I ordered the guy to re-open it for me ehere I cleaned the lens and the protecting glass with high quality lens cleaner.
door
Couldn't believe it how clear my camera become after hitting it few times.. Lol . Thanks Zuhairdhuwaib
door
After panicking all day and then reading thru these posts. I eventually used a nail polish cleaner to wipe my lens. And voilà! !!! My pictures are now brighter and not blurry no more. Thank u all.
Score 1
3 opmerkingen:
this is very helpful. thanks a lot!
door
i just made my camera more blurry
door
was your camera just blurry ir did it have scratches. cuz mine is just burry and it didn't really work
door
Hold 'capture' button until the subject comes in focus, then release the button.
Score 1
Hey Jamie, here are some things you can try:
-Make sure camera lens is clean
-Turn on Anti-Shake
-Play around with the auto focus settings
-Hold the camera button (on screen) for a second, let it focus, and then release the button.
-Turn on Sports Mode
-Let me know how it goes
-Hope this helped
Hello. I would suggest downloading a new camera app, but you did mention this problem only started a few days ago...you can go to or contact your local phone store and they will help you. I hope this helps.
hi all. i was facing the same prblm... believe or not but seriously shook the phone for secs and bluredness of camera .. was gone... god bless india
Hello all, I have the solution to this problem. I called Samsung and got someone who knew the solution. When taking the picture, HOLD down the 'snap'/'capture' button, until the picture comes in focus, then release the button. SMILES EVERYONE. ☺
Update (12/29/2017)
Select subject that you want to photograph
Hold down button
DO NOT release button, until subject is in focus
DO NOT TAP, KNOCK, BANG, SMASH, STOMP, OR ANY ACTION that could eventually cause more damage. Think about it, if you tapped yourself on the side of the head Every time you didn't operate properly, what do you think would happen?
Hi, I hope this works for everyone. I was sold to HOLD the capture (shutter) button and the picture will focus. Hold the capture button until it takes the picture.
This has been the solution for me. They all should be the same.
Mine is S8 and i faced the same problem
Just tap the phone from behind 2-3 times gently
It worked for me
All I did to cure the problem of a blurry photo was, hold down the button and do not release it, until the tablet has brought the picture in to clarity.
You could clean it with microfibre cloth and alcohol. Afterwards put a piece of scotch tape (clear) and press down to get into the smallest crack. It was recommended by a friend and it worked for my J1
I just tapped my note 2 and its now working properly
pm me. i have discovered the fix just now. same here im using note 3.... https://www.facebook.com/brian.alegre.58
Score -1
3 opmerkingen:
door
Brian, iam here now. Why do I have to go to Facebook to see your answer? You are using this site. Please just answer here. (I don't have Facebook)
door
I am facing same problem... my rear camera is not clear and have scratch on camera lens. What should i do?
Aftab pakistan mrnice786@facebook.com
door
Voeg je antwoord toe
Jamie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 62,042
