Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
Sensitive screen after LCD screen replaced?
When making calls the phone will go on speaker or mute after the LCD screen was replace
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
This just sounds like it might jut be a faulty screen there's no way to stop it being to sensitive
Was dit antwoord nuttig?
This actually sounds like the devices proximity sensor isn't functioning properly.
If the screen were "too sensitive" then the issue would also be present when the device is away from your face, such as the reported ghost fingers issue.
Chances are the device requires a UV screen over the proximity sensor. Some devices, such as the white iPhone 4, must alway have this or the result will be exactly as you've stated.
If you need parts for your fix, I'm sure you can get them here at www.ifixit.com
Voeg je antwoord toe
Brenda zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 269
