I suspect there's a problem with the microphone cable.
I just noticed today -while on a Skype call- some static sound registering while using the build-in microphone of my MacBook. I installed LineIn (in order to have some microphone pass-through) and found out that while tilting the display, the static was becoming worse or disappearing altogether on certain angles. Hence, I am suspecting damage at the microphone cable.
Is there any way of fixing this issue, without taking the whole computer apart?
Also, the static seems digital in texture; is there a chance it's not the cable, but something else? Mind you, did all software/firmware tricks I could think of.
I could also attach a recording of the issue.
Is dit een goede vraag?
1 Opmerking
So, in case I will have to replace the microphone cable, is there a specific part number available for the microphone cable (I cannot find a replacement cable on ifixit), or am I out of luck in fixing it myself and I should send the MacBook for service?
door Thanos Tourtouras
