Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2521 Vragen Bekijk alle
not getting a signal from my phone?
hey just recently replaced the battery and lock button on my phone. So while I was doing that I may damaged some of the vital components relating to the connection for either the antennae or the for the SIM card. I am not sure which it is i went back and checked both but they both seem to be fine as far as I can tell. Any tips or tricks?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
when you take the battery out of the iphone 5. your antenna sits beside the battery connector.. be sure that if you took the antenna off.. when putting it back on its sat nice and tight and make sure you havnt squashed the antenna connection thats on the logic board.. sounds silly but its very easily done. they bend and break.. you could also try turning the phone on and off. if that doesnt work put the phone in aeroplane mode and back off again.. if that doesnt work plug your phone into itunes and hit restore... theese are the main reasons for a no show signal.. i hope this helps good luck
Was dit antwoord nuttig?
1 Opmerking:
So i tried restoring the phone and it encountered an error so I'm stuck without a phone for now until I can figure out the restore. Is there anything else I can do?
door
Make sure time and date is correct
Voeg je antwoord toe
Gabriel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 62
