Ga door naar hoofdinhoud
Samsung Galaxy S Blaze 4G SGH-T769 is a T-Mobile WiFi Smartphone
12 Vragen Bekijk alle
Broken screen and lost files.
My screen recently cracked but on the inside. The crack lines are visible and only the LCD buttons on the bottom turn on and not the screen. When I would unlock it , it would make the unlock sound. Now it doesn't so it means my screen can't sense anything. Can that be repaired and if not is there any way I can get all my files back?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hey Dennis no panic keep calm, ;) Good day.
If its just the screen and digitizer that went out, there is nothing to be scared, it probably gradually broke after maybe a fall or something similar,
As its not a super super bling bling phone I would say you have either the choice to google a way to back up your important data if is there any and purchase a new phone, Maybe a powerfull and cheap chinese phone ---> http://www.aliexpress.com/item/Original-...
or if you have motivation and confidence fix the screen yourself, but first before fixing you need to be sure why it broke, if you remember sitting on it or banging against a table ground a fall... What ever because if is something causing it to brake, to much current for example, I don't know I am guessing here, it will brake again....
for your lucky some one nice wrote a nice tutorial on Fixit with easy to follow steps: Samsung Galaxy S Blaze Display Replacement
For a new Screen Digitizer you have this one here for example ----> http://www.ebay.com/itm/New-LCD-Touch-Sc...
or with the T--Mobile logo ---> http://www.ebay.com/itm/USA-New-OEM-Sams...
its up to you, you could aswell search a phone specialised shop next to you, but they would make it really more expensive.
Before ordering on ebay Make sure you have the right model with your device.
Up to you cheers Mate.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Ps: If you purchase one of the Screen with digitizer, you wouldn't need to use a Heatgun, and could jump step 6 because it would come already with the whole front including the digitizer making your life really easier
door
Voeg je antwoord toe
Dennis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 325
