Ga door naar hoofdinhoud
2001 Buick La Sabre Limited's RPM gauge drops to zero while driving?
My Buick's rpm gauge goes from working just fine to 0 in a matter of 20min. The car jolts a little bit when this happens and used to turn off completely while waiting at a red light/stop sign/idling. Can someone help me figure out whats going on?
Ive replaced the following:
Spark plugs/wires, fuel filter, serpentine belt, MAP sensor, Battery (brand new and 200$), gasket seals, oil change.
Thanks!
Is dit een goede vraag?
Score 1
1 Opmerking
A faulty crank sensor can cause rpm issues along with poor running conditions!
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
When it "goes to 0," does the engine shut off, or does the car mysteriously recover and keep on working? Could it be a faulty ignition switch?
My Accord used to just randomly turn off while in the middle of driving, and it took me a couple of months to figure out my ignition switch was bad. I replaced the ignition switch and things worked perfectly since!
Was dit antwoord nuttig?
Score 3
Can someone tell me why my 2000 Buick LeSabre speedometer not working RPM and Signal lights
1 Opmerking:
Did you get the problem fixed
door
Voeg je antwoord toe
tarah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 28
Altijd: 3,287
