Ga door naar hoofdinhoud
Uitgebracht in september 2013. Schermgrootte - 480 x 800 pixels, 4,3 inch. Intern geheugen - 4 GB, 1 GB RAM. CPU - Quad-core 1,2 GHz Cortex-A5, GPU - Adreno 203
Why can I not increase the brilliance or back light
i have fitted a new screen and digiliser assembly and all is working i have reset to factory settings but the problem is the back light or brilliance is very dim i have gone into settings and it is on maximum setting i have also tried on automatic setting no differance can you help
Is dit een goede vraag?
Score 1
1 Opmerking:
can any one help
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Hey grout705,
Did you try to change the backlight screen timeout, go to Settings - Display - Sleep. Then choose the screen time out duration.
You can also tell the phone screen to always stay lit when it is plugged in via USB. Go to Settings - Developer Options. Then check Stay Awake.
-If you tried those please comment to let me know.
*Hope this helps*
Was dit antwoord nuttig?
1 Opmerking:
I have the same problem...
Changed the digitizer and lcd unit, all works fine (after a terrible 10.000 times of in and out) but now the backlight is very dim.. Did everything you said but still no solution
door
Voeg je antwoord toe
grout705 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 29
Altijd: 841
