Ga door naar hoofdinhoud
Fourth generation Honda Civic
33 Vragen Bekijk alle
Starter won't come out
I took out the 2 bolts to the manafold and the starter will not come out... Are their more than 2 bolts holding it in. All other cables and all are taken off...
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hey mate, there should only be a short and a long, 14mm bolts and the two electrical connectors holding it in. Make sure you have removed two 14mm and not 2 10mm bolts. If you have, just give it a bit of a jiggle or lightly tap it with a hammer and use a long pry bar, but be careful not to be too rough.
Hope it helps
Was dit antwoord nuttig?
1 Opmerking:
Where is the long bolt located
door
Voeg je antwoord toe
Teri zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 566
