Ga door naar hoofdinhoud
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
119 Vragen Bekijk alle
My headphones port is not working, how can I change it?
I've had this problem since I dropped my tablet a couple of weeks ago, the headphones port isnot working, I tried different headsets and the result is still the same.
how can I eject it and change it if that's possible?
Thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Hey mate, after a bit of searching around, I found out you can replace it. If you use the guide to open it up (step 19 shows the headphone jack); Samsung Galaxy Note 10.1 Teardown
Also you can buy the headphone jacks from places like this; http://www.etradesupply.com/oem-samsung-...
I hope it helps you.
Was dit antwoord nuttig?
Voeg je antwoord toe
Mostafa Zeid zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,879
